Bad points Really Short Steerer - 170mm (Have a +20mm steerer extender turned down to fit if you want it )
Tight thread in Caliper mount. I can tap out, or drill/ helicoil or I can leave as is. Up to the buyer
I decided I wanted longer ones so these are for sale. Good for overhaul maybe?
I have removed the snap valve non-return valve to take the snap valve out of the equation (google "SPV devolve" and there is a thread somewhere that explains things) like this hereI should have the removed bits but will have to double check
Rebuilt with 10Wt Fork oil. made the forks feel a bit wooden to me TBH . With the SPV chamber up high to give decent compression damping, the forks were a bit digital. With the SPV chamber lower to give plushness , forks dived a bit and wallowed. Put the proper oil in and stick the snap valve back together and they should work well, I think. After all these forks are supposed to be XC - locked with the snap valve and blow off when there are bumps
Rebound doesnt seem to have a great effect either.
Pics on request. Make an offer. Collection welcome
