Our utility room has a very chilly floor, making it the coldest room in the house by a long shot. It is currently stone tiles straight onto concrete.
I want to replace this with something waterproof, hardwearing, easy to clean but mainly something warmer, with more thermal insulation than the current sod all.
If I use levelling compound to put something above the rough and lumpy tiles, there’s about 20mm of height to use; if I remove the tiles there’s probably nearer 40mm.
The inlaws have just put laminate in their utility room, which includes a foil faced underlay layer, but I get the impression laminate isn’t good if it gets wet. I was thinking about vinyl, but what can you put it on? There would be room for thin celotex board, but I presume it isn’t rigid enough on its own without something between it and the vinyl.
Research on the internet is hampered by lots of dodgy sounding solutions and things like underlay advertised as having excellent insulation properties that is somehow still suitable for use above underfloor heating. Yerwhat?
I don’t know much about floors, but I’m happy doing the grunt work… or am I just better off getting a man in and leaving him to it?
