If it boings up and down with some air in the air chamber then the air side is working fine!
I’ll bet the lockout is seized in the on position, or there’s something blocking the damper shim-stack. Only option is to disassemble the damper to check.
I enjoy fixing things, and find it hard to give up but after 200hrs I’d be heading towards the bin!
My 2008 Laurins are in the garage, looking cosmetically very poorly. However the damper is probably working so if you can be bothered to do some research into whether they’re compatible I’ll happily exchange the damper for a few beer tokens + postage.
I also have a fox 32 vanilla r qr 140mm with some stanchion wear (hey – it’s a fox!) going spare. Still buttery smooth…
