basic, but very very good. mines an 07 one, no idea whats changed since but IIRC the rebound has a new part number so maybe its taken care of.
the DLO is a lockout, doesnt realy maintain more than half an inch of sag.
the rebound is adequate, but could do with either seperate tuning to allow faster high speed rebound and slower low speed rebound or a different setup from the factory. Its more a comment than a complaint, it works perfectly well, but when ive got the rebound set as fast as i like, its barely containing the top out. Never seen inside, but suspect its more on orifice than a shim.
Compression damping is almost non existent, DeCarbon damper with orifice’s.
I’m picking holes in a very good fork, its very stiff and very low levels of sticiton, which IMO are the first two things i’d want in a fork. Its just that i’d like to be able to afford the extra compression damper, and a more advanced rebound damper.
