Afternoon all
So... after the weekend my Wotans (2007) are poorly - started the weekend with a bit of a top out and finished with less travel than before (stanchions are only about 145mm long - 160mm forks!) and they sit an inch into that with no weight on the bars - you have to pull the forks/bars apart to extend them further.
Phone call to magura this morning resulted in a diagnosis of a broken FCR (flight control- basically the travel adjust) and a quote for £195 to fix them. I'm assuming that the seals are leaking and letting air into a negative chamber
Anyone got any experience of these (or similar) magura forks? Planning to strip, clean and regrease and see if it helps as the part alone is £110 from magura
Hopefully I can either fix the leak or replace the seal, whilst at the same time sorting out the top out issue (known issue with early wotans that was fixed with a replacement damper assembly - mine are s/h so no warranty)
Magura dont seem to have a proper maintenance guide on their site either like the step by step rockshox ones, only an exploded diagram in the user manual
Chers
Tim
