@TomB – download blackmagicspeed test – and run it. It’s a disk speed test. I suspect the disk is on the way out so as per @gofaster make a back up now, if you don’t have a backup device sign up to dropbox/google drive and and least get the most important stuff saved/uploaded. The machine can run really slow when the disk is nearly full but the GF’s 2012 Mac HDD is dying and the machine runs like a DOG ! (I upgraded RAM from 4 to 10 and it helped but it needs a new disk which will be a 256 or 500 SSD when I get time)
Tell us how full the disk is and also how much RAM you have (full disk and 4gb ram is a really bad combo !)
@cody – yes it will be transformed ! In terms of speed you have something like (using blackmagic) the following (so you will get 3-9 times the speed). A 250gb SSD is about £100 these days
Stock HDD running fine 75
Stock HDD running slow 35
Modern HDD (7200rpm) 110
SSD 250
I don’t think your machine is SATA3 (latest up to date internals for disk data transfer) but if it is you can get SSD at upto 500
