Had a crunch on the top of the cassette so thought a clean and re-grease was in order .
Once I figured out how to get into the hub found the internals to be abit tish.
One set of bearings captured in a race , 1 Set loose . A freehub that appears to be non serviceable ( might be wrong ) and a fairly rubbish sealing arrangement.
Once I had found and cleaned all the bearings after they rolled out across the garage floor , the hub went back together OK .
Setting up the cup and cone tolerences took time , but once i mounted the cassette onto the freehub the fun really began .
Tightening the cassette tight enough to stop wobble on the freehub caused the cup and cone and axel to tighten up and no longer run free . So I can either have wobbly cogs or a free spinning axle?
Going to strip it again to see if im being a muppet ( likely ) , but with so few parts cant see where im going wrong .
