I'm not saying it's that for definate, but if it is, it will get worse and you'll slowly loose more and more travel as more oil leaks out
_IF_ it is that, then when you remove the lower legs, LOTS of oil will come out of the damping side. (there should be only 15cc in there for lubrication) Basically, remove lowers to check, then drain damping oil from top of damping leg, remove rebound shaft (Push out from below) then remove the 'plug cap' that the rebound shaft slides through and replace both inner and outer O rings on it. Reassembe, refill with oil. There's been a fair few Rebas, Revealtions and Pikes that have had this problem (My Pikes included) but if you're handy with tools, it's an easy and cheap fix. 🙂
Otherwise, off to TFT with them !
