When researching, i’ve found a lot of conflicting advice on the correct grease to use.
Personally…
Coppergrease – I use this on things like seatposts and occasionally bolts that have a habit of seizing.
Finish Line Teflon grease – Good multi-purpose grease i use for pedal threads, wheel axle bolt-through thingie majigs and pretty much everything else including VPP linkage.
Stay away from lithium based grease products as they can damage seals in suspension etc.
For chain lube i use Finish Line Cross Country Wet Lube, just don’t put too much on and leave it forever as it does collect a lot of dirt.
