i used gt85 on my chain for years, used as a frequently applied summer dry lube it was fine as it evaporates off leaving a coat of teflon behind, i've been using a dry lube from a bottle this summer and it's been hard to tell the difference. Gt85 is no good as a winter lube though as the weather will just wash it away far too quickly, for winter/wet weather i use finish line wet lube which has been brilliant.
For bearings i use a grease like shimano's or a high temperature axle grease, worth getting a small bike grease gun, most of the tubes of grease screw straight on.
cables etc gt85
discs – rubbing alcohol or disc brake cleaner, prevention is better than cure so ideally remove wheels from bike brfore squirting gt85 or wd40 about.
Thats my opinion, and has served me well for years
