Just changed frames (from an old Iron Horse mk111 to a Heckler) and about to build it up. Before ordering a new headset I wanted to check the folowing : Ive gone from an integrated headset on the Mk111 to a standard one on the Heckler and Im concerned that a Hope headset at 31mm stack height is not going to give me enough steerer tube as I had cut steerer tube on the forks so as flush with stem and 1/4 inch spacer on Mk111. I dont want to be forking out for new forks so was wondering how much lower than the top of the stem can the steerer tube safely be? – or should I be cautious and go for a lower stack headset? – something like a Crank Bros Cobalt C XC. Any advice greatly appreciated. Cheers , Colin
