So a few weeks into owning my EX8 the rear suspension started to make a creaking sound, a lot like a bottom bracket kinda creak- in fact thats what I thought it was until I checked the pivot bolts to find a few were quite loose. I nipped them up and the creaking stopped.
I’ve had the bike a few more months now and on a night ride the other day I noticed the bike was making a loud CLICK sound as the rear suspension goes through its travel- the noise occurs about mid way through the travel. Its loud enough that initially I thought it was chain slap as I was going over a rutted field. The best way to replicate the noise is to bounce on the pedals while stood up.
The CLICK is loud enough that i’m not sure I want to ride the bike until I get it fixed as its really noisy and I wonder what could be wrong. Its a very different noise to the creaking I had previously. Just a single CLICK or TICK type noise.
Things i’ve done that have made no difference;
-Checked the pivots(All), pedals and non driveside crank arm are tight
-Shifted to different gears at the front and the back
I did wonder if it might be something to do with the DRCV shock- can the RP2 DRCV make a loud single CLICK noise if theres something wrong with it?
I’ll probably have to get the bike into the LBS, but thought i’d post up here and see if the hive mind has any ideas.
