Righto, gone from DT Swiss 5.1 rims to Stans 355's and from 2.35 High Rollers to 2.25 Nobby Nics. Saved nearly 1.5lbs and it's rotating mass so maximum benefit.
Changed the E13 DRS chain device to a Gamut dual, which saved about another 1/2 lbs or so.
Got about £200ish left to spend so is it?
Sell the Pikes (454 air u-turn) and get some Thors or Revelations teams. This should save approx 3/4lbs. (This will cost a bit more than the £200 if it's the revs)
or
look elsewhere such as seat posts,saddles,foam grips and maxle lites etc. for example, Carbon posts and Ti fly saddle instead of Thomson and Ti Belair.
Just the carbon post, saddle and maxle lite will also save about 3/4lbs ish as well. This option is slightly cheaper than changing the forks
Bike already has XT all through and carbon bars & 540 pedals. Plus an RP23 rear shock
My view is probably the forks, any other opinions on which way to spend?
