presumably it is physically winding itself down so you have to physically wind them back up again. I can’t see how else that happens.
Since there will be a tiny amount of play engineered into the spring helix (just so it can be turned by hand) then then the spring would wind itself back down the helix (which in u-turn forks is fixed: the whole spring rotates with the u-turn knob) on long bumpy descents if there is nothing else to oppose that rotaion, of if there is too much play between the spring and the helix.
So:
I would first check underneath the u-turn knob: have a look at the excellent guides from tftuned or sram on what it should look like if heralthy and how to do it all back up: you need to see if you have three springs with three little ball bearings on them (and one or two might not be enough to oppose any rotation of the spring), also check the condition of the underside of the knob itself which should have several individual circular indentations which make the ‘clicks’ as you turn the knob. If these indentations are knackered ie worn into each other it may be that as the spring compresses and extends, the lack of springs/ball bearings or lack of ‘clicks’ allows the knob and therefore the whole spring to rotate and creep downwards. At which point i would have thought you needed a new u-turn knob.
If it is all clean and ‘crisp’ then grease the srings, balls and underside of the u-turn knob and do it all back up (there is a torque setting somewhere iirc) then have another go downhill. If it still winds down, it may be that the helix is worn to the point that the spring moves up and down it too easily (and overcomes the spring/ball bits in the u-turn knob): you would then need a whole new spring (which comes with the helix and rod to the bottom of the lower leg and the top cap).
Hope that helps!
