Just been up the woods to do some trail polishing basically picking the trail that runs along side the stream after the river crossing.
The smaller of the two tree trunks blocking the trail beside the stream now has a small dirt ramp each side to make it rideable.
Having crossed the stream using the second bigger blocking tree trunk and doubled back on yourself the tree trunk that blocked the path has a dirt ramp so you can ride over it but only on one side.
When you turn right to head up away from the river there was the path you crossed with two deep muddy tractor tyre ruts. If you stick to the right there is now a raised path that keeps out of the mud.
On a separate trail where there was a log across a narrow gully that rotted through. The rotten log across the gully has now been replaced been replaced by a badly built bridge.
Now finishing my work and ready for this evenings ride.
