Viewing 21 posts - 1 through 21 (of 21 total)
  • Lord forgive me…Hans Dampf 2.35 29er on the front, faster rolliing rear?
  • davosaurusrex
    Currently running a HD on the rear as well but I’d just like something a bit faster and lighter. Needs to have strong sidewalls, Nobby Nic snakeskin seems the obvious choice from Bike-Discount.de for £32-ish although I’m not sure whether to go 2.25 or 2.35. They’re also not that much lighter and I’ve read some complaints about very fast wear. Would like to give tubeless a go as well so tubeless ready would be a bonus. Any recommendations or votes for the Nobbys?
    wobbliscott
    Nobby’s work well, that’s the set up I’ve currently got and been running over the winter. But as we’re moving into summer and hopefully drier conditions, I’ll probably stick a Rocket Ron on the back. I’m keeping the HD up front, it’s brilliant. I’m sure there are other alternatives, but the Schwalbe setup is pretty good.
    buzz-lightyear
    You on the Trailstar, or the quicker Pacestar on the back?
    Clink
    HD on front Snakeskin Racing Ralph on rear here. Top combo.
    mattjg
    IMO the weight of the HD’s not worth the grip for XC/ST and it deadens the trail a bit too. Nic + Ron for me, 2.25.
    davosaurusrex
    Trailstar front, pacestar rear, would still like something quicker
    jezandu
    Perhaps I’m being thick but how do you have a faster rolling tyre on the back. Surely both wheels roll at the same speed? Variation in grip I get, variation in speed I don’t.
    Candodavid
    Snakeskin Ralph on the back
    thisisnotaspoon
    It’s just another way of saying less rolling resistance, i.e for the same effort a less grippy compound or tread pattern should be faster. Obviously some things help both grip and rolling resistance, like high TPI casings and light weight. A lot of people like to run a ‘faster rolling’ rear tyre as it does less work in the corners, and uphill when it is doing the lions share of the work it’s heavily loaded.
    jezandu
    My point is if you have a HD on the front having an RR for example wouldn’t roll any faster because it is limited to the speed of the slower tyre. Rolling resistance is only going to be as good as your slowest tyre, if that makes sense. Obviously if you had two RR on one bike versus a bike with two HDs then there would be noticeable difference.
    Rorschach
    Jeza-Put a 40a Mud spike on the front and a slick on the back and report back with your findings 😉
    bigyinn
    If you have two slow / resistive tyres on then you have more resistance to overcome, its a cumulative effect.
    Therefore if you reduce the resistance of one tyre (by changing it) you reduce the total resistance in the system.
    robinlaidlaw
    Most of the rolling resistance comes from the rear tyre, it’s more or less proportional to the load on the tyre and the rear is usually carrying at least 50% more load than the front so you can make a big difference to how fast the bike rolls by swapping the rear for a faster rolling tyre.
    GaryLake
    Nobby Nic 2.25 Snakeskin here due to clearance issues with the HD. No regrets tbh, the HD on the rear has always been overkill except for when I did FOD DH in the wet.
    Leave it on the front all the time now though.
    GaryLake
    Also +1 for rolling resistance being nearly all about the rear tyre.
    jezandu
    Thanks bigyinn and robinlaidlaw that does make sense, I just couldn’t picture it like that. I run a lesser tread for my rear tyre but that’s more to do with cornering and how I like my bike to feel, never associated with it actually being quicker.
    Scienceofficer
    Now its drier, consider putting the pace star HD on the front and a pace star snakeskin Racing Ralph on the rear. Constantly amazed by what it can do.
    davosaurusrex
    Racing Ralph looks interesting SO, have you run yours tubeless? Few whinges on CRC reviews about them not sealing well
    Scienceofficer
    I’ve been tubeless for years now. The trick is to make sure you get the right one with snakeskin walls, not the silly paper thin sidewalls. I find it weeps a bit of clear fluid which shows up as damp patches about the size of a coin around the tread, but pressure holding is fine, as per any other tubeless tyre.
    shinsplints
    HD front
    NN rear, both snakeskin & both tubeless
    Ace
    davosaurusrex
    Those of you running NN rears, do they roll noticeably better than HD’s?
The topic ‘Lord forgive me…Hans Dampf 2.35 29er on the front, faster rolliing rear?’ is closed to new replies.
