Hi,
I am part of a team of students attempting to design and make a human powered boat hoping for a bit of advice on derailleurs.
I am wondering if it is easy/possible to buy or create a hub with 3 different sized sprockets which uses a rear style derailleur (able to tension the chain) but will not freewheel?
Also, could anyone possibly explain to me why freewheel mechanisms never seem to be included on the hub which is being directly driven by the cranks?
If anyone is interested here is a little backround info on the project:
We’re planning on having two recumbent riders pedaling crankshafts which eventually power a propeller.
I’m currently trying to work out the best way to connect the two riders together so they can deliver maximum power to a drive shaft which is located between the riders.
One option would be to use a standard tandem but with the angle of the drive chain changed. However, we ideally would like independent freewheeling which this cannot achieve. I am considering connecting the two cranks with separate chains to a shaft between the two riders where freewheels could be attached.
Any help/advice on this would be hugely appreciated!
Many thanks,
Emily
