Right then… your carbon frame will be coated in lacquer, basically think of it as being made of plastic.
Mucoff is fine to use, just wash it off in the prescribed time. If you want to keep dirt and stuff off it cover it in Miracle Shine – it'll look blingtastic, and keep the frame a little bit more protected.
Generally carbon's easy to tke care of, just watch for scratches dents and cracks. If you get a crack, send it back 🙂 doublecheck your warranty too, I've got an E-120, and Whyte were fantastic when the frame cracked due to general use, not abuse.
I'd recommend covering areas that are likely to wear with copter tape, from the biketart shop (google it). it's proper 3M stuff, easy to apply, leaves no marks and is tough as an Irish gypsy.
