I’ve been tidying up and servicing the pashley tandem I was given at the weekend (previous thread here):
Front bars and all grips have been replaced. Next job was to sort saddle heights. The stoker post was fine, but when I tried to raise the pilot’s post, I found that it was only inserted by about 15mm!!!
I need to raise the saddle height a bit, so it looks like I’ll be needing a new post.
All the pilot/stoker bar arrangements I can find for sale seem to be separate posts and stems – this one has the saddle sitting forward of the post on a separate rail, and the stoker stem is integral.
Anyone have any idea where I could get a replacement for this from?
If I stick an inline post in, with a stoker stem attached, I’ll be too far back, and my stoker won’t have any room for her knees.
that brompton thingy might be a goer, although it looks like a right bag of spanners 😉
I’ve had a look at the sjs website already, may have to give them a call to see if they’ve got anything knocking around that might help.
This is just a pub/shops hack tandem, so a thomson is a bit OTT 🙂
I have ridden it as it is, and being all steel, I’m not that worried about things bending – so one option is to just put up with having my saddle a bit low.
There are tandem-specific post adaptors for mounting stoker handlebars to seatposts. The one on your tandem is a very old design. SJS cycles can supply you with the appropriate design for £25. You’ll need a new seatpost as well,of course.
EDIT: OH and get a set of stoker bars to go with it. Hands are then placed forward rather than back – this assumes you have reasonable width hips 😉
Posted 11 years ago
Viewing 8 posts - 1 through 8 (of 8 total)
The topic ‘Long shot – where to find a tandem seatpost with stoker stem?’ is closed to new replies.
