Viewing 24 posts - 1 through 24 (of 24 total)
  • Long, low, slack and ETT. What am I missing?
  • chestrockwell
    I’m currently thinking about changing my bike as I think it’s a bit cramped at times. All this talk of long modern bikes made me think a new one, a bit longer would be just the job.
    Problem is my pea brain is having trouble working out the figures. My current bike has a ETT of 620mm in large where as the new ones I’m looking at are 630mm in large or 650mm in XL. Great stuff I thought, should be just the extra bit of room I need.
    But then I look at the stems. My current one has a 60mm, down from the 70mm stock. The new bikes run at 40 or 50mm so in actual fact the total length will either be the 10mm longer if I go XL or 10mm shorter If I stick with a large. So ‘long’ doesn’t actually mean longer in total or am I missing something?
    I don’t want to buy a new ‘long’ bike that actually ends up being shorter than my old one! For reference the current bike is a Orange Alpine 5, the new one either the 5 or Segment.
    kimbers
    is reach not a better measure?
    STATO
    ETT only works if you factor in the seat angle (usually steeper on modern bikes) and the height at which ETT is measured (this is also affected by the head angle).
    Much easier to use Reach if you can find it for your old bike. This is a horizontal measurement from the BB to where it would intersect the top of the head-tube.
    ChrisL
    If you feel cramped when seated then ETT and stem length is probably relevant. If you feel cramped when out of the saddle than as others have said above reach is more important.
    STATO
    Also, the new ‘longer’ trend is to allow you to use shorter stems for the same total length, so it shouldn’t be a surprise it works out like you state. If you actually want a longer stretch to the bars, combine a longer frame with a longer stem. Even really long bikes like mondrakers offset this with 10mm stems.
    Daffy
    Reach is almost as pointless as ETT.
    You’re better off calculating the actual distance from the top of the seatpost to the TDC of the Fork steerer.
    chestrockwell
    Cheers for the replies. I get the reach/ETT bit and it feels fine when standing so looks like I need a bigger frame. I’m a bit surprised ‘longer’ doesn’t really mean overall but guess there’s plenty of other factors at play.
    STATO
    ChrisL – Member
    That presumes you just fit the saddle where it falls and dont adjust it to suit your preferred position. Entirely probable a person will put the saddle in the same setback (relative to BB) on 2 different bikes. Seat angle change of 1deg is only about 10mm at the typical height ETT is measured.
    kerley
    Exactly. The bikes are not longer to give more room, if you don’t have enough room or feel cramped it sounds like the bike is too small or the stem is too short. This would be the case with whatever geometry or style of bike.
    chestrockwell
    It’s when I’m seated it feels a bit cramped. At the end of a ride my palms can feel quite tender and if I ride seated with my hands in the position they feel most comfortable they rest just in front of the bar (760mm so not narrow).
    benpinnick
    Longer only really applies to the average wheelbase of a given bike in reality. Everything between the smallest and largest frame of any specific bike is just a size.
    STATO
    chestrockwell – Member
    Move your seat back then, or get an offset post if your already at max set. You could fit a longer stem (you say you’ve fitted a shorter one) or get a longer bike (with a longer stem than stock), but that will just mean a longer standing reach, regardless of brand or model.
    thepodge
    Prime candidate for stepping away from the numbers on the Internet and trying a few out in real life.
    I also seem to remember reading that Orange bikes got shorter this year but I could be wrong.
    chestrockwell
    Seat is as far back as it’ll go and don’t really fancy any of the droppers with layback. I fitted a shorter stem but also wider bars so it should even out right? The reason I kept away for XL was that I had one years ago that felt too big. I don’t really want to play around with longer stems tbh, I’d prefer just to change the frame.
    Very much agree but I’m a couple of weeks away from having the time to sort a demo and there’s some decent deals about NOW that are taking all my power to resist. 🙄 😆
    Now I’ve got the answer that LLS doesn’t actually mean longer overall that rules out the large bikes. This then leads me to the Segment most likely.
    chestrockwell
    Oh, and the articles I’ve seen for the new Oranges suggest the 5 has got longer but the quoted figures suggest otherwise.
    The 4 I saw today had a 40mm stem so that may be where they’ve got shorter.
    epicyclo
    The ability to ride uphill?
    Rubber_Buccaneer
    Me too. I can understand what all the angles and measurements mean but can’t translate that to what a bike will be like to ride. The only thing I can do is ride it and like it or not
    Rubber_Buccaneer
    I’m not so sure. Traditionally good climbing bikes have me poking the nose of the saddle up my arse to keep everything in balance. Could a longer, steeper seat tubed bike protect my virgin ring piece?
    epicyclo
    Rubber_Buccaneer – Member
    So long as you don’t fit a ThudBuster you should be ok… 🙂
    Rubber_Buccaneer
    chiefgrooveguru
    This year’s Five and Alpine are definitely a little shorter in reach and chainstay length. Both have longer forks than before and the Alpine is slacker too so that adds some wheelbase back. I saw some articles saying they were longer but they were either comparing to 2015 or earlier, not 2016 bikes, or being typical journalists…
    My long/low/slack hardtail climbs incredibly well – super steep seat tube makes a big difference.
    kimbers
    agree completely
    long reach frames need a tiny stem and therfore wider bars + a stee seat tube to get all the benefits of the extra room to manoever and stability
    slack seat tube angles are a throwback to compensate for short top tubes, back when everyone thought they were great
    thepodge
    Buying the wrong bike because it’s a good deal is a false economy. Ignore the numbers and see what feels best.
    I don’t think the Segment is all that long by today’s standards. LLS is just marketing BS these days.
    chestrockwell
    Agree again, however I’d expect a Segment (or 5)to feel in the same ball park as my Alpine 5 so have no worries about suitability, it’s just the frame size that counts. This being the case it looks like it’ll have to be XL as that will at least give me room to find the best fit.
The topic ‘Long, low, slack and ETT. What am I missing?’ is closed to new replies.
