Loft insulation
[Closed] Loft insulation
[#3707994]
OK, daft question coming up. I think the optimum depth of insualtion would be deeper the beams in the loft. I want to floor the loft for additional storage. I think if I just get the flooring sheets from B&Q and lay them accross the beams compressing the insulation that will at least partially negate the effects of the insulation. So how do I easily lay the flooring without compressing the insulation? Thanks.
Posted : 23/02/2012 4:45 pm
batons on the beams to raise them ? - i hope thats the correct method as thats what i wanted to do !
Posted : 23/02/2012 4:46 pm
I only had 100mm depth in my loft joists. So I boarded the loft over glass wool. Then put down celotex / kingspan, then another board over the top.
The total insulation is now greater than the equivalent of 270mm of glass wool.
Posted : 23/02/2012 4:48 pm
Joists running at 90deg to the existing ones tied to the existing joists with [url= http://www.expamet.co.uk/angle-plate-0 ]some of these[/url] then lay the floor sheets on the new joists.
you could even fill the void beneath the flooring boards with extra insulation if there is room
Posted : 23/02/2012 4:51 pm
compressing the ins will make it work roughly the same as ins at the reduced thickness
Posted : 23/02/2012 4:54 pm
b&Q do stilts to raise the boarding up;
[url= http://www.diy.com/nav/build/insulation/loft-insulation/loft_storage_stilt/Diall-Loft-Storage-Stilts-12-Pack-11837507 ]http://www.diy.com/nav/build/insulation/loft-insulation/loft_storage_stilt/Diall-Loft-Storage-Stilts-12-Pack-11837507[/url]
cheap, light - what's not to like?
Posted : 23/02/2012 4:55 pm
wwaswas - they look like something a rubbish DIYer like me could manage.
Thanks everybody.
Posted : 23/02/2012 5:05 pm
 Rio
[url= http://www.toolstation.com/shop/Construction+Materials/Builders+Metalwork/Loft+Flooring+Legs+175mm/d210/sd2797/p44016 ]Toolstation[/url] do some more substantial legs if you want to go that way, but I used [url= http://www.diy.com/nav/build/insulation/loft-insulation/B-and-Q-Insulated-Timber-Loft-Board-L-1200-x-W-320-x-D-123mm-10647753 ]this[/url] for the part of the loft I wanted to use for storage.
Posted : 23/02/2012 5:27 pm
I had a question like this recently that I posted on mybuilder.com. They this an 'Ask a Tradesman' section which is quite helpful because tradespeople are the ones who answer your questions (instead of people like us that actually don't have a clue :/).
http://www.mybuilder.com/questions
Posted : 15/05/2012 5:20 pm
 Bear
cellotex sheet over the joists then screw your board through cellotex into joists.
be careful with your ventilation.
Posted : 15/05/2012 5:39 pm
