Viewing 10 posts - 1 through 10 (of 10 total)
  • Lightish hardtail for wife will take taper forks 120mm
  • motox2k
    Guys,
    Im after a hardtail frame that will take tapered forks for the wife, needs to support upto 120mm (I have the forks all ready).
    I have been reading a little and what I have read suggests you can run tapered forks in any frame that runs an internal headset? is that correct? what are my options.
    Stu
    njee20
    456 carbon?
    motox2k
    oh needs to be cheap 🙂
    dickie
    Gribs
    Secondhand Giant xtc frame?
    Nipper99
    new decade virsa
    si-wilson
    We have a small Chumba hx1.£299 and very nicely built 🙂
    Chumba hx1
    bigblackshed
    Ragley piglet???????
    tetsujin
    2011/12 boardman pro or team if you can find a secondhand frame.
    chives
    Buy a second-hand cube Ltd. With a 120mm fork in the geometry’s not too dissimilar to a Stanton slackline (short chain stays and all that guff). I love mine. They’re 7005 alloy, (which is tougher than 6061 – at the minor expense of some corrosion resistance – clean it), so as tough as old boots.
    Enjoy.
    Edit – sorry, missed the bit about the tapered steerer. Not sure if an external lower bearing would render that possible or not..
The topic ‘Lightish hardtail for wife will take taper forks 120mm’ is closed to new replies.
