OK – so I'm moving down the valley next week and have a great fun trail back to my house – and now it's getting darker earlier I'm gonna need some sort of light to show me the trail home..
I've not been night riding for years and have lost touch with light technology.. what should I get?
Ideal spec:
Bright enough to ride in the pitch dark (i.e. at least equiv. to a 10w halogen)
Cheap-ish (100gbp max)
Ideally all in one unit – or at least super simple mounts (i.e. no tools!)
Small
Can last a few hours and maybe have a 'get me home' mode
Something like the Hope Vision 1?
Knog Gator 105 – brighter but has separate battery – but simple mounts.
NiteRider minewt USB
Cheeky sod bit industrial .
Never one to pass a chance to post pics of my stuff
there are changes on the horizon .
I can do you a cheapo 6oo lumen light like this one with just HI LOW setting but you would need a battery pack for it.
The latest incarnation is this one 1200 lumens
and it is ace
I have opened the bottom up to flood the front wheel area with light that does not normally get out of the housing
check these out the first pic is with the front blacked out so no beam
next is just beam with the bottom blanked out
and followed by one as it should be .
These shots are a bit bright and not meant to be beam shots they are meant to show the beam pattern close to the bike
This light is going to a guy in Ohio as soon as I have taken some proper beamshots of it
Trout, how much for the second one? bearing in mind that due to my complete electrical incompetence (blew up light circuit board last time I tried to fix my light) I'd be after a built version.
Thanks (mail in profile if you don't want to print prices)
Trout posted a review of the DX, now referred to as the "Bastid" light, on here a while ago.
It isn't just about how many lumens for your £, imo. Especially when you see the strip-down of the Bastid light.
I think that the lights produced by some of the Home-Brew light types are of a far better quality, the type of lights that will see you through many seasons of night riding.
Especially so when paired up with Batteries and chargers from Smudge.
If you ride a moderately priced to expensively priced bike, then perhaps fitting a Bastid light to it would seem a bit silly.
Hi Guys,
Troutie, Looking mighty impressive with the bottom channelled out… how about the sides?
At the moment a 15V 2.6Ah £45 and charger £23 coming supplied ready to power a troutelight.
troutie can fill you in for how long it will last light time or I can also do a 5.2Ah for enduros (please ask for price as these are now built on request) .
One other Q though Trout. The Low Batt, what is the signal ?, does the main light just start to flash or something when the battery gets low ?.
What is the signal to the user of a low Batt ?. Seems like a detail, but I'm just curious.
I_Ache
A 12 volt battery is good for the 600 lumen light I have a battery but no charger as I sold the charger with the last light .
Solo
the driver can be configured to flash the light at half charge
and again it will flash at low charge it will also cut off to protect the batteries if it gets too low .
these are all user configurable
