A switch like this would work (I think, it’s been a while..):
http://uk.rs-online.com/web/p/push-button-switches/0224675/
This will illuminate when power is connected. I have one on on the light I made and is great for finding the switch in the dark. You can also wire in a 3 or 5mm status LED but this would need a casing modification. This can be programmed to flash at certain voltages. This can also be done using the main LED’s to indicate low voltage.
You might need to take the light apart, find out what driver is in there then have a look here: http://www.taskled.com/ to find the technical info for your driver..there’s info on there to tell you how to program it..
