Yes, my XC 29er hookless rims were out – I had to rebuild the rear after a year as nipples kept breaking. Adding 2mm sounds wise on those.
Personally I wouldn’t believe any quoted ERD. I’ve built probably hundreds of wheels and the only one I’ve ever got the spoke lengths wrong for was for an ERD I found online and didn’t measure myself. Never again!
The few LB rims I’ve built are all out by about 4mm on the ERD, which means add 2mm to all the spoke lengths in reality. Not great, but if you know to expect it you can counter for it.
To be fair, I’ve built hundreds of wheels over the years. Most rims are pretty much bang on for their quoted ERD, but I’ve got to say that like LB, Stans ERD’s are somewhat optimistic. Maybe not quite so bad, but I add 2-3mm onto the ERD of Stan’s rims every time when calculating spoke lengths, otherwise you can end up with plenty of thread showing on the spoke ends when built!
