It’s massive! I’ve sure there used to be smaller version on the market. years ago I remember seeing them the size of bike bottle (750ml that held about 600)
Anyway, my 2p. High mountain streams are fine to drink from. I remember hearing that 100m downstream is fine if the water is very aerated and exposed to sunlight (after you, I insist 😉 )
As well as bacteria and viruses you should be wary of chemical contamination. Heavy metals, pesticides and other such things – these aren’t removed by tablets. I think carbon filters are best for these – cheap and normally in any purification system.
I’ve never had a problem in Scotland/Lakes/Wales drinking from mountain streams with the obvious precautions but no tablets or filters.
I’ve been quite horribly ill on several occasions from kayaking trips on lower sections of the same mountain streams.
