http://fcdn.mtbr.com/attachments/shocks-suspension/967429d1424880714-vorsprung-corset-chumba01.jpg
So far everyone is suggesting a linear relationship which isn’t accurate for a linkage bike, especially a VPP.
Look at this graph. Wheel travel on the x and leverage ratio on the y. The first thing to note is that a blur had quite an atypical falling rate towards the end of its travel, compared with other bikes. What you ideally need to know is what that graph looks like if you continue the green line out towards the right. You have to extrapolate a fair bit, which is prone to error, but it looks as though the line would continue to plummet – ie the ratio would fall. This means that you’ll be somewhere near a 1:1 ratio so your extra 6mm of shock travel might only buy you 6-10mm of rear wheel travel.
You could always just measure the rear wheel travel.
My other comment would be that although nothing fouls in the garage, by the time you add in some wheel flex / frame flex, you may find that things are rubbing. Just keep an eye on this on the first few miles of riding the thing.
Anyway, enjoy. I always wanted a TRc.
