Was reading the cycling plus road bike of the year review and the thing that stood out was how heavy the bikes all were (relatively for bikes well over 2k – most were over 8kg)
So lets see your uci limit or below builds. Mine is a smidge over 7kg so doesnt count..
Price inflation = weight inflation at low/mid price points.
Getting under the 7kg mark isn’t easy at all – it requires a top end groupset and fairly exotic wheels.
My 2010 Addict has a light frame, carbon bars/post etc and still comes in over the 7kg mark due to Ultegra/Ksyriums.
My Aeroad 8.0 was actually 7.2kg with pedals so sub 7.0kg without…. pretty good considering the deep sescion wheels and it’s an aero frame. oh and OnzaDog it was delivered in less than a week 🙂
Stock image. Weight is <7kg but without pedals or cages. Goes up a bit more when I add 1.5L of water, saddle bag and Garmin. Not actually weighed mine with proper scales though to check.
I’ve sold the frame now, but I had a Hong Fu 066 which came in well under 7kg for not *that* much (relatively). According to my nerdy spread sheet, built up with 24mm Chinese carbon tubs, Record F/R mech, Planet X crappy lightweight brakes, K Force light chainset, it weighed 6.4kg with two Arundel cages, SPeedplays, and a Garmin mount I’ll try to dig out a pic but I mostly rode it in a heavier build with 34mm Corima tubs and a power meter.
My old Roubaix has been on a diet but even after that it only made it to 8.2kg (with cages and pedals) and that’s despite if having some fairly light bits (Dura-ace C24 wheels and a Dura-ace cassette for example). I suspect it’d take a lot of cash to get it sub 7kg if it’s even possible!
Just under 6kgs, complete with cages, pedals, garmin mount and dirt. Its done 30,000km so far and seems pretty robust even at that weight, although I do have a slightly heavier pair of wheels that I normally use instead of these 1kg pair.
Old but still good in my opinion, not at all sure what I would replace it with, maybe try an aero bike instead?
7.4kg in the pic. It goes under 7.0 if I swap the saddle for something less padded and remove the bottle cage and Garmin sensor. And I’ve not trimmed the seatpost or steerer.
So how much to buy a sub UCI weight limit (6.8kg) bike these days? Surely it’s waaaay more than 2k? Or am I living in the past lol
Cost less than a cycle to work scheme, including buying the complete secondhand bike and replacing everything bar the frame and forks (which aren’t in themselves light).
The only secondhand bits in the end was the rear mech and bifters (and the frame/forks).
It’s really not that difficult to do, just spend money where it saves the most weight. That means alloy stems and bars, but going to town on things like wheels where you can get some really light stuff for relatively small cost. For example those wheels weigh 1250g and cost less than Mavic’s Ksyrium’s (the entry level ones, not even the pro/elite models).
Defy Advanced SL (Medium), with Dura Ace everything, carbon bars and stem, and no seatpost. When wearing the carbon wheels it’s bang on 7kg. Lightest frame Giant ever made and a Paris Roubaix winner thanks to Degenkolb. But I prefer the Dura Ace/Sapim/Mavic CXP33’s it’s wearing here. Light is nice, but stiffness matters too.
Will be out on it tomorrow first thing en homage 🙂
The race bike is 7.4 kg, so doesn’t quite make it. Propel (and TCR) frames are heavier than this one, and we won’t mention the disk abominations they are passing off nowadays!
Oh and Dolan Seta track bike is under 7kg, but brakes are important on a road bike 😉
EDIT:
This one doubles the value of the car I carry it in. So yes. As was the race bike.
Even a fairly burly saddle weighs <400g, so you’d have to swap it for an imaginary one and perch on the seat-post.
I think overall the thread pretty much proves what I said way back up there that bikes at or below the limit are still fairly rare/exotic, given that we’ve got 1 picture (and maybe one hiding under the broken pic links) so far.
Yeah. My race bike is 7.6Kg with 7900, deep wheels, power meter, etc. It’s not at all unusual to see pro bikes about 7.5Kg unless it’s a GT contender on a mountain stage.
So not as silly a question as all that. Road bike are usually sold sans pedals too aren’t they?
Yes they are sold either without, or with £2 plastic jobs and the manufacturers quoted weights are without. So as far as silly questions go, not hugely silly.
However obviously when talking about UCI weight limit, that’s a bike ready to go racing, which obviously requires pedals.
It’s ~350g IIRC, it’s a cheap saddle. I had one of those cover-less saddles for a while that took it under 7.0kg then eventually swapped it for a normal SLR flow (carbon body, ti rails), so it’s around 7.1kg now. I’ll ride it into work next week and put it on the scales and prove it.
My point was, that it’s almost down to the limit, for under half even the lowest budgets some people are talking about. Throw another grand at it and make it a £2k bike and you could shed even more weight (carbon bar, carbon stem, carbon wheels, the fork is still an alu steerer!). And plenty of stuff is still ‘comfortable’ rather than picked for weight (bars, seatpost, saddle). If you wanted to do it all new you could buy a chinese carbon frame for not much more than I paid for the original bike.
Weightweenie builds don’t need to be expensive if you sped the money sensibly.
Trek Emonda 54
Ultegra Di2 with DuraAce Chainset.
Fizik OO Saddle and Bars and R1 Stem.
Vittora Corsa G tyres
Easton EA90 SLX Wheel with TI Skewers.
Garmin Vector Pedals.
Topeak Carbon Cages x 2
6.8kg on the head with everything bar bottles, saddle bag and Garmin.
I have some EE brakes and some Jagwire Elite cables to fit that should knock another 150grams off that.
As has been pointed out i reckon it wouldn’t be that hard to custom build a bike to the UCI limit for under 2k
As long as you start with a sub 1kg frame and decent wheels that is. Thats not to say it would be suitable for my 14 stone frame, but it would be possible..
My old PX pro carbon weighed 7.4, and I built it up for about 700 quid!
