No longer running this as I got a FS frame but here you go
Can't say nothing bad about them. For what you pay you get a very well sorted frame. Used mine as a commute bike as I've been carrying an injury so not ridden off-road much. Would recommend one any day too.
mate, i just love them
the whole speccing, building and trying them.
like i have said time and time again also, where can a 6ft4'' 21stone bloke get a test ride on a suitable bike, moreso a full sus bike with the correct shock or spring.
and i am pretty good financially, so why not.. 8)
i did mate
rode it once, 45 mile slog over crossfell and high cup nick….
felt ace going downhill with pikes on, but on the flat and uphill it fellt wrong
i felt way too far over the backend.
I was thinking along similar lines – MX Comp airs and some suitably burly rims. A lot of people seem to be running these with huge forks (and then complaining about how they climb 😉 . I thought the whole point of them was that they were designed to give slack angles around a 100mm fork.
Anyone running one with shorter forks got any experiences to share.
Mine with 100mm rebas. It's plenty slack enough with these on, but when I get them serviced I think they will be going up to 115mm. I have no idea how the bike manages to turn with 160s on though!
It needs a short stem (the one in the photo was changed after 1 ride down the street, and dropped down the steerer too)
I like the way it rides in comparison with my standard inbred (which has rev u turn 130mm forks). It is way more lazy than that even with the revs wound right out, but comes into its own on steeper downhills or techy stuff (the little i have ridden). It just feels like it wants to be smashed into/over stuff.
It climbs well too, easy to get weight over the front end on steep stuff.
I loved it but you needed 3" risers and a pile of spacers beneath the stem to make it feel right. Otherwise it felt like the front wheel was a 20"er not 26".
Chainsuck nightmare frame though.
It was a hoot though and I rode like a hooligan on it. Now sold.
140mm pikes it was fine but it felt better on 130mm revelations IMO. it did climb better than you'd expect too.
I've found mine the opposite – each time the bar height is dropped a bit it rides more confidently and i can really get weight over the front and push into corners. Mind you, it looks like I am quite a bit smaller than you, so it may just be the same relative bar / saddle height 🙂
Going from a Stiffee i initially thought it was too slack especially for tight twisty stuff but after a couple of rides i've got used to it and really like it. I run the Pikes at full travel but will try experimenting a bit, though in the Peaks the 140mm gets well used.
