Viewing 40 posts - 1 through 40 (of 44 total)
  • Let's see those 69ers….
  • fenred
    Sitting at work, bored out of my nut and had a light-bulb moment that bar a set of forks I have all the shit components in my parts bin to build a franken69er-ish stylee pub/hack/play/lets see what this malarky is all about bike.
    Pics invited for inspiration purleeese 😀
    plyphon
    I must say I was slightly mislead by the thread title.
    Pyro
    Just waiting for a higher rise stem to arrive, so my chin’s not resting on the steerer quite as much. Currently used as a commuter, but well be using it for longer touring/bikepacking stuff as well.
    tomhoward
    All the pics I have of 69ers are most definitely NSFW.
    Sorry.
    Solo
    fenred
    Indeedy, hence not being able to google “69er images” whilst sitting at work 😉
    will
    quintet100
    Untitled by Quintet100, on Flickr
    rOcKeTdOg
    Bernaard
    Now orange with a fat front, so technically still a 69er
    will
    They’re not lookers are they 😆
    Bernaard
    Do you have one?
    If you don’t, try one, then maybe you’ll see why a lot of folk ride them
    Yes they will never be the best looking bike but the ride overrides that looks in my humble opinion
    I have had 29ers, but always seem to return to my 69er
    rOcKeTdOg
    butt ugly
    but fun to ride
    tazzymtb
    fenred
    Oh I don’t know about that…no different to clambering into bed with a laydee with one boob bigger than the other….might still be a fantastic ride 😉
    qwerty
    Ooo, lots of inspiration here, I keep toying with the idea of 69ering in my Handjob (15.5″ frame), and then converting to SS. May get a Hummingbird fork and go from there.
    What front 29er rim would match my DT 5.1? Or any matching 26/29″ rim combos that match each other as I have a DT 240 SS & Hope XC in the parts bin.
    Anyone any experience of http://www.trickstuff.de/de/products/exzentriker_KL.php?
    Keep your 69ers cummimg.
    rOcKeTdOg
    miss matched rims are better, it follows the theme 😉
    qwerty
    Nooooo, I’m a tart. The olive green Hummingbird fork should match my flat green Cove nicely and the theme will then be set.
    GRAEMEJONES
    As the above comments say, they ride a lot better than they look! 😉
    Meet Goofy
    [/url] Untitled by santarocky, on Flickr[/img]
    chip
    I have a 120mm hardtail and was considering fitting some 150mm forks as I have some sitting around.
    But after some googling which said the bike would be slacker and less responsive and generally worse to ride in an xc capacity.
    And also I would be pushing back the seat tube angle there for putting more strain on the frame.
    Which would then snap and I would die.
    so did not bother.
    So does fitting a 29er wheel on the front not have the same effect.
    Just asking like.
    ronjeremy
    Here we go, like a proper 69er, never fails to make me smile
    martymac
    rocketdogs wanga is winning in the looks department.
    bentudder
    In answer to Chip: going from 120mm 26er to rigid 69er doesn’t slacken things off – remember the 26er will need 12cm extra space at the front for that travel. 🙂 Take a look at the last three pics and note the gap between the top of front tyre and the headtube.
    Incidentally, I’m selling the forks in the last two pics – I now also have a 29er to go with the Hummingbird, so they’re a little surplus. 177mm steerer. I can throw in a suitable front wheel.
    Genesis iO 725 with hummingbird forks:
    Genesis Io 69er conversion by bent udder, on Flickr
    Hummingbird with 120mm 26″ forks:
    Hummingbird by bent udder, on Flickr
    …and with the rigid 69er forks
    Hummingbird as a Penny Farthing by bent udder, on Flickr
    fenred
    Bernaards sov or wills wotevathefark that is for me…
    Edit- ooh that hummingbird!,,,
    Atomizer
    Beauty is etc….
    IMG_2471 by Jones96er, on Flickr
    RestlessNative
    Much better than it was as a rigid 26er
    ajr
    djflexure
    Tranny 69er anybody. Hopefully mine will be ready for HONC.
    will
    Bernarrd – yeah I do have one, see above.
    Fenred – It’s a Giant XTc Composite
    letmetalktomark
    Currently going through a remake – I”m going to try a shorter fork or a 650b wheel ……
    Paulio
    Not a franken-bike but a Trek Top Fuel 69er, bit of a crap picture I’m afraid. Bought from the classifieds, powder coated and built up into my favourite bike.
    Solo
    OOoo !, its a “heres my ugly bike ” Thread.
    clubber
    I 69er’d my inbred with a 440mm fork and a 29er wheel.
    TBH while it was ok, I never really felt that it was different enough or had any real advantage to be worthwhile for where/how I ride at least and reverted back to vanilla 26″
    shermer75
    Restlessnative- nice work, thinking of doing the same to my inbred. Is that a 18″ frame? I’m worried about toe overlap…
    Andy-R
    Not with the NN’s now though – Chunky Monkey and Smorgasbord, which I really like.
    CheesybeanZ
    fenred
    Anyone got a set of steel 26er disc mount forks they want to get rid of?
    RestlessNative
    That’s a 16″, no toe overlap even with a 2.4 Ardent on the front now (2.25 in that pic)
    I don’t have big feet though
    Sanny
    Is anyone running a full sus frame with 29er forks? I have an odd idea about running a 650b Burner with a 29er front end. Is this madness?
    Andy-R
    Sanny – Member
    Well, I’ve got a Trek Top Fuel 69er, but I don’t suppose that counts, as it was designed to be like that.
The topic ‘Let's see those 69ers….’ is closed to new replies.
