I was messing about on the internet the other day and came across a phenomenon known as HDR imaging. Well, after a bit of reading, I decided to give it a go myself, and am quite pleased with some of the results.
Sometimes they look OK and sometimes they look really, really artificial. I think you have to be careful on your subject choice and then use the technique subtley.
Well, they were my first attempt. I guess my aim with the sheep and statue were to make them seem as saturated as possible to ‘posterise’ them. Some of the others on there I attempted more subtlety, but was still trying to extract more from the sky. I guess if I combine a grad filter with the technique, i’ll get good skies without having to overegg the rest of the frame. Alternatively, I could just learn how to use GIMP a bit better…
Sorry Zokes, I didnt realise that you’d actually done those yourself. I have a pretty strong aversion to “HDR” because the net seems awash with totally hideous and totally pointless examples of the technique, which is nothing bloody new at any rate. The best examples are the ones where it’s as little as possible.
bigD, you basically take a load of identically framed shots with different exposure settings to capture different levels of detail where normally you’d sacrifice detail on one thing to get the light right on something else. the shots are then all combined digitally on photoshop or similar.
What is HDR then, and what does it change about a picture? I mean I can see that some of them have been ‘tweaked’ but what has been done? (In Layman’s terms please, eg, “you make the bright bits brighter” or you “take away all the red” etc.) Thanks 🙂
Wiki: techniques that allows a greater dynamic range of luminances between light and dark areas of a scene than normal digital imaging techniques. The intention of HDRI is to accurately represent the wide range of intensity levels found in real scenes ranging from direct sunlight to shadows.
Me: Trying to make a boring photo look interesting 🙂
Some of you are getting some really pronounced effects there, what software are you using?
jojo – essentially you use multiple exposures to capture detail that would have been lost. Cameras can only recover a certain range of brightness values in each colour. Using tone mappign or HDR trickery you can take the bit of a dark photo thats under-exposed and map in the same bit thats brighter from an over-exposed image. This means you can get detail in your clouds while also having detail in your shadows. Makes a somewhat unrealistic image, or possibly a hyper-realistic image. Some can look wonderful, some can look aweful. In the photo below the dark shadowed bit was completely black in one image, and in the image I took where you coudl see that detail the sky and sand were whited out.
This is the only one I’ve ever done that turned out as I half expected. It got used on an online publication too lol.
I’ve been trying photomatix but I tend to get a really grainy result for some reason, cant figure out why for the life of me. Plus it totally screws up the white balance from my canon raw images and everything goes green no matter what settings I use on them.
I quite like that image, in a graphic sort of way, rather than as an accurate representation of life. I think it sort of reflects feeling as well as vision. In an arty mumbojumbo sense.
tomzo – shooting in raw still doesnt allow true HDR – all it does is increase the bit-per-pixel rating and give actual brightnesses, rather than the reduced gamut of a jpeg? If its under-exposed in the raw you still need a second image with a different exposure.
ski – cheers, it’s Formby beach, and yup in the background is the North Hoyle windfarm. URL on flickr for larger image shows up slight focus issues and movement due to two exposures.
My understanding on how to shoot the photos, were to point you camera at the darkest and lightest areas whilst on apeture setting. Then take a photo for every two shutter stops, hence the waterfall took 9 shots. This video probably explains it better and they only use 3 photos, the two extremes and a middle range. My main use is to highlight the whole subject, bringing the darker areas out. The 1st one is the normal photo, single shot.
The HDR as posted above to compare against:
I personally like the rocks better in the hdr, but the sky needs work, and i haven’t been bothered 🙄
Not entirely sure HDR can be any more passe than the use of a camera can be – really it is just the use of all available information rather than binning some due to inadequacies in the media.
lol I love this from one of the tutorials:
Friends don’t let friends do HDR on Drugs
Above, you can see the options I selected. It’s way overdone. The key setting is that “Light Smoothing” with the 5 radio buttons underneath it. Don’t choose anything to below the fourth bubble. Please! For the sake of humanity
Posted 15 years ago
Viewing 38 posts - 1 through 38 (of 38 total)
The topic ‘Lets see them!!’ is closed to new replies.
