I think I saw a CRC ad the other day for a Tacx turbo trainer reduced to £80 or keep your eyes peeled for bargains on eBay.
I was given a series of leg exercises to do a while back by a physio…
– lay on back with knees bent & push hips off floor. Keep a straight line with body & thighs, then lift one foot off the floor to straighten your leg. Keep back/hip/thighs aligned. Hold for 10 & swap legs. Do pyramid of 10secs down to 1 & back to 10.
– Lay on floor with feet raised off floor on a chair/foot stool and keep straight line between shoulders & feet (hips off floor). Lift one leg off, similar to above exercise & do same pyramid set.
– stand side on, on bottom step of stairs with one leg overhanging. Keep toes of overhanging foot raised to stop you bouncing off your toes & do one legged squat so heel touches floor. Try to keep as straight as possible.100 reps each side.
– same squats as above but facing stairs, not side on & do one legged squat so hanging leg comes backwards off step. Same reps.
– take 1 shoe off , so that foot is off the floor. Swing leg backwards & forwards in a smooth, deliberate action. Keep body still & hips level.100 reps each side. Will probably get to 70 or so before it starts burning the outside of your hips. Apparently good for hip flexors.
I was told to do all reps required. If you can’t hold form, have 2 mins rest & carry on.
2 mins rest between exercises too.
