Viewing 13 posts - 1 through 13 (of 13 total)
  • Lee Quarry, help me!
  • Simon
    At the end of the new link from Lee Quarry to Crag Quarry which way do you turn at the Pennine bridleway for Crag?
    ScottChegg
    Right.
    The figure of eight of the Cragg track passes over the Byway. There isn’t a lot to indicate that this is what you’ve come for, so you need to keep you eyes open.
    Simon
    Cheers, I took a lucky guess and found it before your answer. It’s a bit sticky up there.
    ScottChegg
    It’s probably improved it. It was loose over summer, it needs wetting through and packing down.
    It’ll be fine when it dries out.
    pixelmix
    As a non-local, is the link from Lee Quarry to Cragg pretty easy to locate, and do-able without a map? Thinking of doing a quick blast round one lap of Lee, one lap of Cragg (and obviously the link in between) at some point in the next few days.
    I’ve been round Lee once before, so have a hazy recollection of the layout.
    pixelmix
    Bump
    Andituk
    Up to the clifftop section at Lee Quarry (after the skills area) on the redroute, and I believe the new link is on your left just before the trail turns right towards the pond.
    Not ridden the new link so not sure where it comes out, but Cragg is obvious from the PBW, as it passes through it.
    Simon
    The link bridleway is off to your left when you get to the top of “The Ramp”
    When you hit the Pennine Bridleway head right down the hill.
    When you get to the fork head left, down the hill, Cragg Quarry is a few hundred metres along on your left, but is easy to miss!
    HTH
    elaineanne
    i thort there were new signs to be put in or did Tony Lund mention ‘blobs of paint on boulders’ to help find the way to cragg ?
    pixelmix
    Great, thanks folks. Will give it a bash soon.
    pixelmix
    Thanks again. Found the link easily enough and took the right turn thanks to the directions above. Really enjoyed Cragg, which is well signed when you get to into it. Seemed to flow better than Lee (for me anyway).
    TonyL
    I will be getting some proper signage up there soon. Hope you found your way round it all ok in the end. Did you enjoy the new track over the moor on the way back down?
    Should be getting some new sections built in Lee and Cragg Quarry over the next two to three months. New pump track and some more black graded techy stuff in Lee and more red singletrack in cragg. Also hoping to get some beginers style trials sections in at Lee.
    pixelmix
    Really enjoyed it thanks Tony, and easy enough to find (as long as you know to turn right at the byway as stated above). The link will be great when it beds down a bit. Much better than a muddy bridleway. The jumps were a nice addition to keep things interesting on the way down.
    It seemed fairly busy up at Cragg today. I only ride a couple of times a year in Lancs, so look forward to checking it out again later in the year. Think I’ll maybe do one lap of Lee and two of Cragg next time (did the other way round today).
The topic ‘Lee Quarry, help me!’ is closed to new replies.
