Viewing 3 posts - 1 through 3 (of 3 total)
  • Leaky Caliper
  • scholarsgate
    I’ve got a set of Mono minis which have alway leaked from the front brake caliper bore cap. I have changed the bore cap and seal and it still leaks. Anyone else had this problem? Have you fixed it?
    bigyinn
    Have a word with Hope?
    coatesy
    Only once, seal had got snagged/pinched. New seal, lubed prior to fitting, solved the problem. Check the caliper body for any sharp edges that may damage the seal.
The topic ‘Leaky Caliper’ is closed to new replies.
