I think that our combi-boiler might be leaky, but if it is it's not much. We've noticed a small amount of water pooling beneath our combi-boiler. It's a small amount (maybe a saucer full or two), yesterday was the first time we noticed it all winter.
There's no obvious leak but there is a small drop that appears to form around a hole in the pressed steel underside (it might be an unused screw hole) which eventually drops to the floor. It's very slow to form and I think is only forming when the boiler is on (could it be condensation as the pipes heat up in a relatively cold cupboard?).
The water pressure does seem slightly lower than at the start of the winder. Is this a job for a plumber (I'm not going to fiddle myself)?
