My friend is having a problem with her XT m785 brakes. She noticed the rear one felt a bit spongy and would sometimes need to be “pumped up” to work. She brought the bike round and asked me to have a look at it.
It didn’t seem too bad, so as I was pressed for time I just attached the funnel and let the brake dangle vertically. I’ve found this quick bleed quite effective at getting rid of the odd bubble if it is in the lever body after trimming hoses. When I did this a few bubbles came out and lever became firm so I thought great. But then I noticed that as I pumped the lever the fluid was leaking out of the lever body, mainly close to the hole on the handlebar side. It was definitely more than just a drip and if you flicked the lever repeatedly you could actually see it spatter out on to the handlebar.
As the lever was now firm, I took the funnel out and put the bleed screw back in. I then cleaned the lever body with compressed air and wiped it down with alcohol. However I’m still noticing the a bit of fluid building up around the lever body and the lever doesn’t feel so firm now.
Can anyone suggest what might be wrong. There is some evidence of crash damage but nothing too traumatic, at least externally.
[sorry for the long post. I’m in Seattle, so I might be slow to reply because of the time difference]
