Hello all,
I’ve got the builders in! At the moment it is the destruction phase of works, the wallpaper has come off (along with a fair portion of the wall in some cases!) and the carpets are gone. Once the road to recovery is in place I am hoping to have wood floors throughout the ground floor as one of the final steps in the work.
Under the carpet are vinyl floor tiles which are stuck to a concrete floor. The tiles are stuck firmly down and are in good condition. The builder is recommending that the tiles are left down and that the floor will be best laid over the top, he is not just trying to save money/time as he is offering to refund some of quote cost if he doesn’t lift the tiles. He thinks that the tiles are an adequate base for the floor which will have to be laid ‘floating’ as a result of varying floor level across the room.
I’ve previously read good advice on here about wood floors and this generally seems to be along the lines of don’t float – stick. From what I have described does this still sound the case, is the builder advising a bodge or should I take the builders advice and save everyone time and money?
I am not planning to spend the earth on the floor but I do want something significantly better than cheapo laminate that doesn’t bounce around when I walk on it.
Any advice from someone who’s done it before? And if the best way is to lift the tiles and stick the floor down how can level differences be coped with given that self-levelling or screed will only be able to take out a couple of millimetres of difference I guess.
Keppoch.
