- This topic has 126 replies, 62 voices, and was last updated 10 years ago by MoreCashThanDash.
Large 4×4 reversing over my bike
Nipper99Free Member
so, your dim enough to leave your bike on the ground in a busy car park where other vehicles are passing and it get damaged and that someone elses fault – i think he / his insurnce co will run circles around you.
jonridleyFree MemberFor what it’s worth I didn’t use ‘the small child’ argument with him, and wouldn’t use it in a claim because it is peripheral to the situation – I just mentioned it here to help explain my point.
feltFree MemberWhat relevance is the “large 4×4”?
I have a large 4×4, but it’s just a car to me. So can we stop trying to get all the tree huggers on your side?
Every time that I leave my bike at the back of my car, I always make sure that nobody can run over it, I have even moved it on occasions when I have heard/seen the car next to mine want to reverse.
As a driver of a “large 4×4” or any other car, you do not normally reverse with the steering turned so sharply that you would hit either of your wings on vehicles parked next to your own car. So I find it hard to believe that the car’s owner drove in such an irresponsible manner. I know that now feel angry but surely some of this is your own fault and you know it.
Without photos, accurate measurements, etc, what is your proof? The word of a few mates?
Legally, there are so many ways that any judgement against the car driver can be declined that it is just not worth the trouble. You will be lucky with the £20 offering. Sounds crap, but that’s the way it is,but a very good learning point for everybody following this post.
chipFree MemberPersonally, I would suck it up and put it down to experience and be more careful in the future.
Going back to your small child example.
Whilst packing up you told a small child to sit in the position where you left your bike.
The car next to you reverses out over said child. And you then posted that on a forum claiming it to be the drivers fault.Do you think you get much sympathy, more Likely people threatening you with a lynching.
You were careless and due to a misfortunate series of events your bike got damaged.As said, suck it up,move on.
tmb467Free MemberI once left a rock at Llandegla cos I’d been late walking back to my VAG wagon
When I eventually got back I found some idiot had ridden an orange 5 over it
It was ruined
JunkyardFree MemberLegally, there are so many ways that any judgement against the car driver can be declined that it is just not worth the trouble.
No there is not I am sure all the witnesses will say bike wa sin x place for x time person got into vehicle reversed over it told the to **** off and drove off. The best they could hope for was contributory negligence as you cannot reverse in to stationary objects just because someone parked it poorly!! You are moving it is not the only way to crash is for the moving thing to hit the stationary thing which was ALWAYS there. Only on STW would you even need to “debate” this.
L leave my car on busy roads where vehicles pass all the time- is it my fault if it gets hit or the one in the MOVING vehicle that hits it ? thats not even a starter for 10- as its blindingly obvious
The car next to you reverses out over said child. And you then posted that on a forum claiming it to be the drivers fault.Well they have just run over a child who was there all the time – If i drive down the road and someone is in the road can I just run them over as they should not be there? When I do its their fault ? Can io only run them over fwds or backwards? – what about both as they should have moved /not been there?
You are a QC I assume
steviecaptFree MemberI think in this day n age, when insurance companies will look for any loop hole in order to avoid paying out for a claim, you are going to need all the luck you can get, at most 50 – 50 i would say, i hope im wrong for your sake op,but i would be amazed if they pay up, good luck, you will need it lol.
feltFree MemberJunkyard, You seem to have a lot of experience in these issues.
What exactly are your transport legislation / experience in these matters?
RichPennyFree MemberWhen I drop my nipper off at nursery, standard procedure would be park, remove buggy from boot, leave buggy behind car, remove and insert child, walk away. I would be surprised if someone ran over either my buggy or me and my child and claimed it to be my fault! Where else am I meant to go?
chipFree MemberHe left his bike where it was not safe and it got run over, get over it.
A friend left his £800 air rifle on the ground at the back of his car in the car park of a HFT shoot.
Another friend ran it over I identical circumstances.
But the owner had the good grace to realise despite being upset if he had not been a **** and left it there it would not have been run over.It even occurred to him what happened could happen when he placed it there but decided the risk was tiny as it would only be there momentarily.
Stop trying to blame someone else if he had put his bike safely out of harms way instead of leaving it in the way expecting others to avoid it .
trail_ratFree MemberHow did this car turn quick enough to run a bike over left behind a van – none of my 4x4s will do that.
Or by behind the van do you mean in the vacinity but actuallyin the middle of the road ?
TuckerUKFree MemberHe reverse out of a space, instead of reversing in and driving forwards out as per basic common sense & the Highway Code. Bell end of the highest order, and his being a bell end caused damage to your bike. Simple.
scaredypantsFull Memberpark, remove buggy from boot, leave buggy behind car, … Where else am I meant to go?
Pavement ? Why would you obstruct the road ?
projectFree MemberBOLLARDS, thats what you want, lots of them to create a safe and sterile area round your bike.
or a bike forcefield,will warn off errant motorists by sounding a message,and a strobeing light available from http://www.bikeforcefields.con
feltFree MemberTuckerUK – Member
He reverse out of a space, instead of reversing in and driving forwards out as per basic common sense & the Highway Code. Bell end of the highest order, and his being a bell end caused damage to your bike. Simple.Look at any supermarket car park and look at all the “bell end” car Parker’s you complete muppet!
NorthwindFull MemberBloody hell… He was at a trailcentre, you park nose in because you want easy access to the boot. Same reason everyone parks nose in at supermarkets. Get a grip.
projectFree MemberBloody hell… He was at a trailcentre, you park nose in because you want easy access to the boot. Same reason everyone parks nose in at supermarkets. Get a grip.
I drive a van with rear doors and always reverse into spaces, no problem for me getting in the back, the housekeeper usually unloads the trolley into the van.
NorthwindFull MemberHow big a van? I have a choice, either park nose in and be able to open the boot, or park rear in and not (well, or park rear in and sticking out into traffic, but that’s not so good).
actually getting a trolley to the boot can be impossible in a busy carpark too, unless you park nose-in.
feltFree MemberNorthwind – Member
Bloody hell… He was at a trailcentre, you park nose in because you want easy access to the boot. Same reason everyone parks nose in at supermarkets. Get a grip.project – Member
I drive a van with rear doors and always reverse into spaces, no problem for me getting in the back, the housekeeper usually unloads the trolleySo……are there any signs in place to say that you ‘must’ reverse park?
I doubt it.
shortcutFull MemberIn my eyes this is difficult. Putting your pride and joy on the floor in a busy car park and not keeping an eye on it is perhaps a little silly. Take responsibility for your own belongings. If you put it out of the way you wouldn’t get it run over. Would you put a baby in a carry chair by the back of a van on the floor and turn your back on it??
Driver should have looked where he was going – but also had a point.
nealgloverFree MemberHe reverse out of a space, instead of reversing in and driving forwards out as per basic common sense & the Highway Code. Bell end of the highest order, and his being a bell end etc etc etc.
Because I’m not a “bellend” when I park my van at Trail Centres, I always reverse in.
Then I get in the back of the van by climbing over the seats
Get my tools out and take the two bikes to bits.
And pass the bits of the bikes over the front seat to my missus through the window.
We then reassemble them in a safe place where nobody can reverse into us.
When we have done our ride, we do all the above (in reverse)We can then drive out safely, forwards.
All because I don’t want someone in the internet to call me a bellend.
(Sometimes I’m not sure its worth it ?)
ninfanFree MemberNo different from reversing into someone else’s badly parked car in the supermarket car park. its still the drivers responsibility, and their insurance company are going to have to settle it.
citizens advice, letter before action to their solicitors and small claims if they don’t settle
JunkyardFree MemberWhat exactly are your transport legislation / experience in these matters?
entirely non existent but I am not sure they are required to work out if the moving or stationary objects, in this scenario, was responsible for the crash.
RichPennyFree Memberpark, remove buggy from boot, leave buggy behind car, … Where else am I meant to go?
Pavement ? Why would you obstruct the road ?There is no pavement because I’m in the middle of a car park. Similar scenario to the OP really. When I’m reversing in the same car park, I wouldn’t be swinging the back end into an area that I couldn’t see first.
cruzcampoFree MemberDid you get any pics of the 4×4 after it reversed into the bike, for insurance company etc? that pic would be very valuable.
davidtaylforthFree MemberNo offence OP, but I think you need to wise up. The man was in a 4×4, that means he doesn’t have to pay much/any attention whilst driving, and I bet he’s got his additional “4x4c*nt” licence, which means he can just shout and swear at you before speeding away.
crashtestmonkeyFree MemberIve never seen a reverse-parked car in a trail centre car park, presumably for the boot access reasons given. I’m a police driver and we are taught to reverse park to be able to make rapid safe deployments but it is unrealistic at trail centres as illustrated by the faff described above in passing parts through. I also NEVER leave my bike lying on the ground in a car park either, it gets put somewhere out of harms way (eg propped up between front of my car and fence/wall/hedge).
Like others I can’t see how someone can reverse out of a parking space and hit something tight behind your neighbouring car (esp a big 4×4), you must have left the bike much further away from rear of yours, and exposed to danger, than you imply.
The driver sounds a knob and in his position I’d feel responsible and offer to sort something out, but I don’t have much sympathy with the OP because leaving a bike lying around and getting it run over is like leaving your car/house unlocked and getting it screwed- your negligence/laziness is a contributing factor in it being able to happen.
Damage is likely to be less than his insurance excess so he may choose to settle with you than risk you making a successful insurance claim which will impact on his NCB etc without any benefit?
feltFree Memberdavidtaylforth – Member
No offence OP, but I think you need to wise up. The man was in a 4×4, that means he doesn’t have to pay much/any attention whilst driving, and I bet he’s got his additional “4x4c*nt” licence, which means he can just shout and swear at you before speeding away.……and that’s my point!
The hatred of 4×4 drivers in this mad world. We are all tarred with the same brush, and yet, some of us also ride MTB like the rest of you.
fervouredimageFree MemberJunkyard, You seem to have a lot of experience in these issues.
What does it matter? His posts in this thread are based on obvious common sense and a basic understanding of the application of law In relation to a moving vehicle striking a stationary object.
fervouredimageFree MemberThe hatred of 4×4 drivers in this mad world. We are all tarred with the same brush, and yet, some of us also ride MTB like the rest of you.
Does being a 4X4 driver make you irritable and defensive?
feltFree Memberfervouredimage – Member
What does it matter? His posts in this thread are based on obvious common sense and a basic understanding of the application of law In relation to a moving vehicle striking a stationary object.…..and common sense is always law?
tizzzzleFree MemberReading through this thread makes me realise what a bunch of t0ss-pots most of you lot really are.
tizzzzleFree MemberNipper99 – Member
Cheers bud.
Case in point
aracerFree MemberI don’t have much sympathy with the OP because leaving a bike lying around and getting it run over is like leaving your car/house unlocked and getting it screwed- your negligence/laziness is a contributing factor in it being able to happen.
So in your professional capacity you’d let off a scrote who stole stuff from an unlocked house or car because it was the owner’s fault?
feltFree Membertizzzzle – Member
Nipper99 – Member
so, your dim enough to leave your bike on the ground in a busy car park where other vehicles are passing and it get damaged and that someone elses fault – i think he / his insurnce co will run circles around you.Cheers bud.
Case in point
What is your case tizzzzle?
feltFree Memberaracer – Member
So in your professional capacity you’d let off a scrote who stole stuff from an unlocked house or car because it was the owner’s fault?The sad fact is that some judges would actually let ‘scrotes’ off for this reason 🙄
smell_itFree MemberI read a bit of page 1 got bored and then cut straight to page 3, and its sank right to the level i thought, gawd bless you STW 😆
davidtaylforthFree MemberThe hatred of 4×4 drivers in this mad world. We are all tarred with the same brush, and yet, some of us also ride MTB like the rest of you.
It’s the classic stereotype, although I guess it exists for a reason!
Living in the lakes, I get to see some terrible 4×4 drivers. Alot of them probably local, and alot of them nodders in chelsea tractors who’ve just come to the lakes for a weekend away, with their awful kids.
They’re still a bit unecessary though!
tizzzzleFree MemberWhat is your case tizzzzle?
I guess if you have to ask then your viewpoint is different to mine. Which is fine.
ninfanFree MemberThey’re still a bit unecessary though!
Is the ownership of any car with an engine capable of propelling the laden vehicle at more than 70mph not just as ‘unnecessary’ though?
The topic ‘Large 4×4 reversing over my bike’ is closed to new replies.
