Got a few niggling problems with my laptop, wondering if anyone can give some pointers:
Often when I shut the computer down, it turns off and then restarts, several times in a row.
The laptop won’t allow me to safely disconnect my external drive. I’ve set Picassa to save directly to the drive so I can easily edit/add photos on either laptop or PC. It disconnects fine on the PC, on the laptop I have to shutdown before unplugging the drive. Problem exists even after I close all extra processes/task icons 🙁
Every now and then, the laptop will make the ‘bong/beep’ noise that you get when connecting and disconnecting a USB device. It’ll do it constantly for about 3 or 4 minutes before stopping. This is with no USB devices plugged in at all.
After connecting to a BT Fon wireless spot a couple of weeks ago, (think BT Openzone) whenever I turn the laptop on, it shows my wireless connection as having limited connectivity. Disconnecting and then reconnecting to the wireless router fixes it after a couple of attempts. Laptop isn’t normally taken out of the house so it is not using other wireless points between attempts.
Thanks for any advice 🙂
