Pictures of everything in this flickr page..
Gifty paypal or bank transfer please. Pickup in plymouth welcome.
Specialized myka sport frame 2008. 15" £45 posted.
-15" c-t, top tube of 21". Allegedly better standover than equivalent men's hardtail size.
-For use with a 100mm or so fork.
-30.9mm seat tube, comes with qr seatclamp and inline 2-bolt 350mm seatpost.
-Normal 1 1/8" headtube, only 100mm so you can plug a really short steerer fork in it, bargain hunters
-No dents or cracks, but quite a few chips and one bit of cable rub on the headtube.
-All threads, faces and derailleur hanger are fine.
-Also has rack and mudguard mounts, and only veeeery minimal chainslap under innertube chainstay protector.
-Also comes with v brake bosses (not pictured), and disc mounts are faced.
-Weighs in at a shade under 1800g with bolts, hanger and chainstay protector.
-Slightly girly butterfly graphics.
Also
Specialized BG ladies' saddle as removed from £1k ladies full sus (to give you an idea of good/poor quality)
150mm wide at the back with centre cut out, 8mm tear at front but otherwise really good condition. £8 posted.
Raceface Prodigy Stem, silver with black faceplate, 100mm 5 deg rise, normal steerer and 25.4 bars, rust in bolt heads, plenty of scuffs and logo peeling off the front. weighs 199g £8 posted.
Kooka xc stem, 100mm 5deg rise, normal steerer and 25.4mm bars, black with silver faceplate, weighs 125g (!), plenty of scuffs but presumably the bolts are stainless as they are in excellent condition. Had an easy life on my commuter. £8 posted.
Scott stem, Normal steerer and OS 31.8 bars, 110mm with 10 degree rise, all glossy black. Logos all but completely worn off (probably a good thing!) rust inside bolt heads, small bit of cable rub underneath. £6 posted.
Brave Connectors grips, white collars green grips with flange and extra grippy bits on the underside. Well worn and dirty, chips on clamps but work fine. £3 posted or free with anything else in this ad.
