Has anyone had a Lev lock in the “up” position?
Mine is a 150mm version, installed with carbon paste and the quick release collar not nipped up particularly tight at all, just enough to keep the post in place (ie, it would still rotate after a tumble). I removed any dirt from the post and seal after every ride and used Finishline stanchion lube to keep it sliding smoothly.
One day it’s working perfectly, a day later I get ready to go for a ride and it’s locked up. The little barrel in the box is pulling down as far as it can go, so cable tension isn’t the issue, and the kevlar string seems to be under tension. I’ve returned it to the local shop I purchased it from and am awaiting a response (I guess it’s gone back to the distributor), but if anyone here has had that same issue it would be nice to know what the problem is/was.
