Viewing 5 posts - 1 through 5 (of 5 total)
  • Kona Coiler, rear shock upgrade? Which one?
  • tsukawa
    I have recently just got back into riding after about 4 year, being out of the loop and looking at all these rear shock is hurting my brain, the stock shock on my coiler doesn’t like the bigger drop offs and jumps, just wondering what i should think about upgrading to. Also fox seem to be the “leader” but are they the best?
    Thanks
    kimbers
    might be better (certainly cheaper) to get it custom tuned (pushed or something ?) by tf tuned or mojo
    tsukawa
    Ah i’ve never even heard of bike springs being tuned, will definitely look into that. Thanks for the advice
    xiphon
    Talk to TF Tuned or Loco Tuning, for recommended shocks for your frame.
    alaric
    They don’t “tune” the spring, they (or you) can replace the current spring with one with a different spring rate that’s more appropriate to your weight and riding style.
    The damping, however, can be tuned (different weight oil, alterations to internal components) to give you better control over the way the shock responds.
The topic ‘Kona Coiler, rear shock upgrade? Which one?’ is closed to new replies.
