Please mail Ahwrigley@gmail.com. All prices posted recorded. Lots more hi res pics HERE. Detail and pics below summary.
1. Chris King Rasta 1 1/8th inch steerer headset. Immaculate. £55 posted
2. Hope rear wheel. ProII 6 bolt disc hub on DT Swiss 5.1D rim. 32 spoke. QR. £110 posted/ £100 collected.
3. WTB Laser V Titanium railed saddle. £25 posted.
4. Titanium J & L seatpost. 27.2mm x 400mm long, inline. £30 posted
5. XT front mech. M770 9 speed. Top swing. 34.9 clamp. 31.9 or 28.6mm adaptors included. £17 posted.
6. Middleburn square taper cranks. 175mm long. Silver. Includes lock ring & park tools lockring removal tool. £55 posted.
7. Middleburn Uno ring. 32 tooth. Cant remember if 1/8" or 3/32". Pretty worn. £10 posted.
8. Hope stem. Black. For 31.8 bars. 100mm x 10 degree rize. £25 posted.
9. Shimano deore quick release skewers. £10 posted.
10. 3 pairs of genuine magura marta 5.2 Endurance pads. £9.00 each posted.
11. A2Z rotors 6 bolt rotors 180 and 203mm. Little wear. £8 each posted.
DETAIL & PICS
Chris King Rasta 1 1/8th inch steerer headset. Fitted, used for 4 rides and then removed due to new frame, so pretty immaculate. Few scuffs to underside of crown race from removal. £55 posted.
King rasta 3 by carlos_fandango, on Flickr
Hope rear wheel. ProII 6 bolt disc hub on DT Swiss 5.1D rim. 32 spoke. QR. Hub vgc. Rim true, with less than 1/2 mm out of true. Few scratches (see link for pic of worst) but nothing serious, no cracks, or flat spots. Very tiny dent on rear rim, does not show on rim, on side of rim only and too small to photograph and I only found it by running my finger round the rim! £110 posted/ £100 collected. from Berkshire
Note: this is the rear wheel only
P1010381 by carlos_fandango, on Flickr
WTB Laser V Titanium railed saddle. I prefer SDGs so this had very little use. Measures 146 x 270mm. 235 gms VGG. £25 posted
P1010437 by carlos_fandango, on Flickr
Titanium J & L seatpost. 27.2mm x 400mm long, inline. Too tight for my Lynskey frame but thats due to the frame, as this post fitted a steel frame fine. £30 posted.
P1010440 by carlos_fandango, on Flickr
XT front mech. M770 9 speed. Top swing. 34.9 clamp. 31.9 or 28.6mm adaptors included. VGC. Only removed as new frame needs bottom swing mech. £17 posted.
P1010387 by carlos_fandango, on Flickr
Middleburn square taper cranks. 175mm long. Silver. Includes lock ring. Pedal threads and square taper holes are perfect. Few cosmetic scuffs. Will also provide the park tools lockring removal tool. £53 posted.
P1010400 by carlos_fandango, on Flickr
Middleburn Uno ring. 32 tooth. Cant remember if 1/8" or 3/32". Pretty worn with hooking starting to show on teeth but still works with a new chain. £10 posted.
P1010406 by carlos_fandango, on Flickr
Hope stem. Black. For 31.8 bars. 100mm x 10 degree rize. Anodizing has worn a bit in places. £25 posted.
P1010402 by carlos_fandango, on Flickr
Shimano deore quick release skewers. Fitted once so near perfect apart from a tiny scuff on the front. £10 posted.
P1010407 by carlos_fandango, on Flickr
Magura Marta Endurance pads by carlos_fandango, on Flickr
180mm rotor by carlos_fandango, on Flickr
203mm rotor by carlos_fandango, on Flickr
