Shock!….Your Tripster seems to be covered in some kind of mud- that’s not allowed by order of Kinesis – all pics of the Tripster need to be perfectly composed with a shiny bike at all times – if you need to carry it on your back for 10miles across a bog infested moor to get that one perfect pic of a Tripster in it’s natural environment then so be it, it’s a heavy and burdensome cross you will have to bear. There’s also the matter of filthy tyres, the valves are in the wrong position, you’ve also forgot to shift into the big ring at the front and up the rear cassette, the pic does not follow the rule of thirds, i can’t see any sign of bottle cages either? – i bet you are one of those weirdo’s who carries upon their back a mammalian type sack filled with water.
You have a lot to learn, you did get the official Tripster’s owners manual didn’t you?, you are aware that we can enter your garage/shed/outbuilding/house at any point and demand to see the living conditions it is kept in?, and what are you feeding it?……….i use a Muc Off Ceramic C3 dry lube at the moment, sometimes a Pedros Ice Wax but i imagine come wintertime i will need a more generous and robust feeding regime.
Welcome btw………. 😀
