Viewing 5 posts - 1 through 5 (of 5 total)
  • kinesis pro6 disc fork mudguard fitting
  • karnali
    have a pro6 and just about to fit a front mudguard. there is no hole at the top of the fork on the back to pit a bolt into, there is a clear circle but it is covered over. Is this just paint that has covered the hole and therefore just break the seal with a bolt and screw it in?
    thanks
    Lummox
    I’ve fitted my full guards to the same place, mine was clean and visible though when I first went to fit them. Threads by dropout weren’t great and had to be chased out.
    Maybe an exploratory pokey object?
    rlanquetin
    Same as lummox in my case.
    It must be painted over, see if you can get trough with a needle.
    Did you managed to fit the guards at the back?
    karnali
    poked a pen through, no fitted a rack on the rear then fitted an old plastic guard to the rack as that is easier to take on and off for the commute than both a rack an guard.
    antigee
    used to have full mudguards but its spring and dusty in Aus’
    3yrs oldish kinesis forks that came as standard
The topic ‘kinesis pro6 disc fork mudguard fitting’ is closed to new replies.
