My 6y/o daughter has a Carrera Luna 20″ and she’s loving riding it.
Slight issue we’re having at the moment is hills – she wants to do longer rides but after a while is struggling on the hills due to the slightly rubbish gearing on the bike.
Current gearing is 36t front and 7spd 13-28t on the back.
This set up give the following gear ratios:
High – 1:2.8
Low – 1:1.29
So on low when on hills she’s still having to work quote hard.
Now my initial thinking is to just get a wider range rear freewheel – these are available in either 12-32t, 14-34t and 11-34t.
This should help on the climbs as it brings thing closer to 1:1 at the low end (1:1.12 for 32t and 1:1.05 for 34t).
But I then got to thinking that I could improve things further by swapping the front ring. This would mean changing the crank – but I can get a 152mm Suntour with bolt on rings for £24 – and sticking a 32t single ring up front.
This would improve the climbing a bit more and would give a 1:0.9 ratio for a 34t freewheel.
Question is, is it worth changing the front or should I just swap the freewheel and see how she gets on?
The ‘bike-tart’ in me is thinking change the front a stick a purple chainring on for extra coolness and ‘Dad points’.
So do I spend £12 on a freewheel only or another £30 on new crank & ring?
Am I missing anything?
