Hi there
I’m new to this forum, and needed help for my KS post. But I may be of help here 🙂
Have a look at this link, the oil is what makes the post go up and down! Like an air shock.
http://forums.mtbr.com/all-mountain/ks-i900-fixed-fully-rebuildable-home-693843.html
Although you’ve done it now, it isn’t recommended to do it unless you know what you’re doing. It’s the re-pressuring that’s the hard work. I’m an engineer with compressed air available to me, but I still had to modified components to allow me to do it. It needs about 120 psi (about 8 bar) of pressure 😮
My question is relatively simple, so wondering if you guys can help me. I bought my KS post of ebay (groan!). It’s been tampered with. But I’m unsure about the bearing whether it’s been changed or not.
I put the post in slightly (so that the guide bearings are not doing anything), and the post doesn’t rotate at all. Is this how it works? I’m surprised because I would suspect that the roller pins would allow the post to rotate. (I’m guessing that this is intentional, and that the roller pins are pushed back so much that it stops the post rotating…I’ve never seen this application before!).
Any help is much appreciated.
