just an update for those debating 32's or 36's, coil or air.
I started off with 36 Floats and RP23. the frame works well(better than expected) with 36's however some sort of travel adjust would be benificial. swapping to the 32 van QR15, i feel the front a bit low but handling and ride quality is spot on. If i had enough steerer length I could add 1" of spacers but I dont!
the RP23 was ok but lacking compared to what i've been used to(CCDB shod Nicolai Helius FR). Swapped to a Stendec tuned Roco TSTR and the bikes tansformed.Up or down the suspension is spot on.
In summary, if I was speccing the bike from new(instead of from a pile of bits lying about the workshop!) I'd probably opt for 36 talas(or maybe float set at 140mm) and a decent coil with some form of switchable platform damping(or even better a CCDB). oh and stick on a big wide bar also and maybe a 70>80mm stem
As for classification, i'd put it firmly in the AM bracket. it'll no doubt do 27lb XC but it suits 30>32lb in AM guise very well.
