Hi jumping_flea and Gooner,
Thanks so much for getting back to me.
I will try and answer your questions:
Firstly, is the connection near and existing TX/Power line or will it require a totally new build? this could influence things
Not sure what the term TX/power line is but the high power line with three cables crosses the corner of our field. The only pole on our ground is a T off pole where two cables go off the pole at 90 degrees to a local farm. WPD say they want to put another pole 2m to 3m away from that under the three cables to put the transformer on, this is very costly and to me doesn,t seem necessary. would Central Networks allow a 50 kva or kw 3 phase transformer on a T off pole and if so what are the clearances off the floor etc.
All work bar the final connection can be done by anyone you like as long as it is inspected and approved for connection by WPD. This was brought in under the competition in connection regs. Doing the ground work yourself could save you money..
We are doing a lot of the ground works already. Can we use another company besides WPD to say, put this pole in and fit the transformer and connect all except the final connection onto the high voltage cables.
The second option, but only available if there is existing infrastructure in the area, is to get WPD to do any upgrade work as asset improvement and hope that they just charge you just the basic additional work and not the entire cost.
Not quite sure what you mean by the above as power lines do cross our land but I didn't say that originally.
Central Networks normally gives time-scales of 12 weeks from payment to complete the work. However time onsite to install and wire a TX is 1 day to prep and 1 day to connect - cable to pole etc and LV wiring (Including local shutdown and giving residents notice of the interruption)
So would it take 4 man days. 2 men for 2 days or are the teams bigger than 2 men.
Do you think I can get them down on price, besides the pole, transformer and earthing there is 130m of cable to the meter point.
I hope this isn't going to be the actual cost as I don't know how we could afford it.
Any help would be very much appreciated.
