Hi,
I’d been out riding the other night. Got home and as I unloaded the bike heard a tinkle. Of course it was dark at the time so I couldn’t find anything.
Next day I checked my brakes has a little test ride and they seemed OK. I remembered the tinkle and went and had a look around the car. There was brake pad on the floor.
I removed the other pad and tried to push the piston back, but it wouldn’t go. I called a friend and he suggested that I slightly loosen a bleed screw near the brake lever. This I did, the pistons were pushed back and I tightened the screw. Once the pads were re-fitted I tested the brakes but they do not work. Some oil leaked out of the reservoir cap and the brake plunger makes a squidgy noise when I pull the lever.
Any ideas?
Thanks
